2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-09T01:21:08+00:00
    The blog post is from February.
    Greg [MSFT]:
    please unmark this post
    as answered. It is not.
    2016-03-09T01:37:14+00:00
    Some of us may be luckier, in that it seems to work ok.  Mine still seems to heat if I let it go to Sleep naturally, but if I put it to Sleep, seems ok.  Mostly testing it plugged however.
    There are a lot of folks still having the problem in a serious way.  Yet a friend just bought one and describes no problem. So I am wondering, if Microsoft thinks it is fixed, and sees this board as just a vocal minority, we may be irrelevant.  But it seems if your SP4 can demonstrate the problem so readily, why don't you take it back to the store, instead of waiting for a fix that now may never come, if we are a small group?  Further, if it is mostly not waking up, they need to replace them and incur the cost and see what is going on.
    The only reason I'm not taking mine back YET is that I hate the hassle of setting it up again, since it basically is working for me now.  I think something still is not right with that heat.  As I use it more as a tablet, if I have problems, it will go back as a warranty issue.
    2016-03-09T03:13:34+00:00
    Returned my SP4 yesterday. $1500 and the device can't wake from sleep. I could even tolerate that until there is a fix, but MS hasn't even acknowledged this thread let alone addressed the concerns.
    2016-03-09T03:25:26+00:00
    Unproductive and makes windows look bad.. anyways theres an update today. The changelog says something about improve hibernate speed but nothing about black screen of death, who knows maybe its mysteriously fixed!!!
