2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-06T08:32:30+00:00
    You have just described my exact experience with my Surface.
    When plugged into the wall socket, I am fine.
    I do not have the battery drain at all, but just the black screen at times when I am on battery.
    I just hope future firmware releases will fix this issue.
    The only consolation I have is that, I am not alone.
    Thanks for your reply
    2016-03-06T19:26:27+00:00
    How do you see to do the update if the screen is blank?
    2016-03-06T23:50:10+00:00
    push and hold the power button for 30 seconds, then push and release as normal to turn it on
    2016-03-07T18:04:36+00:00
    Finally today the whole day I found my SP4 waking up promptly, but the whole day I used it on power. Shall check this on battery tomorrow and update.
    But for a change none of my USB devices were getting ejected properly, SP4 kept saying its busy using the device though I closed all the apps that's using it.
    Good luck
