2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-05T20:11:01+00:00
    Power button + volume up enters bios there u can disable secure boot if u want to install unapproved apps and applications as well as make other adjustments
    2016-03-05T20:30:50+00:00
    Hello Justin,
    Thanks for your reply.
    All I wanted to achieve is for my Surface to be a little predictable.
    At times, the keyboard will not come out of the sleep mode.
    As I have indicated, to come out of that dead state, I have had to perform the much publicised wake sequence.
    A firmware was releases late February which I promptly installed.
    Am I right in saying this firmware fix was supposed to fix the sleep issues?
    Once again, thanks for the reply.
    Kind Regards
    2016-03-06T04:30:49+00:00
    I seem to get stable sleep with disabling faststart then shutting the machine down(reboot doesn't clear things up) then starting.
    Also disabling lock screen and slideshow
    Unfortunately if sleep is consistent the USB craps out eventually to the point of having to reboot(which is better than a hard shutdown which messes data up)
    Also saw online about the battery drain during sleep issue can be improved by enabling hyperV as well as disabling WiFi
    As for battery life lowering the screen brightness gets better results
    2016-03-06T07:47:08+00:00
    I'm not sure if it's always been like this or if I changed something (since I've been reinstalling drivers, disabled fastboot, etc). But it's pretty clear to me now that my surface pro 4 (with all updates installed, including 2/17) sleeps fine when it's connected to power. It's only when I put it to sleep while on battery that it won't wake up and I have to do a hard reset. In fact it seems like it never sleeps, since there is no record of it having gone to sleep when I run powercfg -sleepstudy after having to do a hard reset.  Anyone else have this experience?
    I've also noticing quite a few errors in the event viewer after a hard reset. I can't tell if they are the cause or just a response to the hard reset. I see a couple of Lock Screen errors, some Perfmon errors and other things.
