2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-04T17:43:52+00:00
    I'm throwing in a "me too" post.
    I have a i5/8G/256G SP4, before 2/17 update - whenever the screen went dark coming back from sleep, I only had to do "Win-P" to come back. After 2/17 update - machine ALWAYS hangs after some time of sleeping.
    • CTL-SHIFT-WIN-B DOES NOT WORK
    • CTL-ALT-DEL DOES NOT WORK
    • clicking on the pencil "eraser" DOES NOT WORK
    • repeated push of the power button DOES NOT WORK
    • detaching the keyboard and reattching DOES NOT WORK
    • no issues with the 2/17 firmware install as I don't have the yellow triangles.
    • disabling going into Hibernate after a sleeping period DOES NOT WORK
    • powering down by holding the power button for 10 seconds and rebooting with the power button DOES WORK, but I lost anything I've done before I rebooted
    • forcing power button and lid close to hibernate only DOES WORK, but if the computer goes to sleep by itself with the timer, I'm forced to reboot.
    • 2/17 install ruined my SP4 experience - my SP4 is practically unusable now
    • computer hanging the display after sleep is RELIABLY AND CONSISTENTLY BROKEN
    I think the only thing I can say about the 2/17 release is - W-T-F
    The problem is most certainly software, not hardware as it was working relatively fine before the 2/17 update.
    • Peter
    2016-03-04T20:46:54+00:00
    I tried some things on my machine that I hope will help fix the problem:
    from an elevated command prompt, I ran: powercfg /energy which yielded 8 errors, including the error that \filesystem\srvnet was trying to prevent my machine from sleeping. On the advice of a Microsoft forum post, I ran sfc /scannow which told me my opencl.dll was corrupted and sfc could not fix it. I then repaired my copy of Windows 10 using the command line tool dism and the instructions here. From there, I ran chkdsk, restarted, reran sfc /scannow which was able to fix the corruption, and reran powercfg /energy which now yields 7 errors, all related to usb devices not entering the selective suspend state. I just did all of this, so I'm not sure whether it will fix all of my wake from sleep issues, but thought I'd pass it along.
    2016-03-04T23:23:35+00:00
    You should just use hibernate if you don't want to return the device... it works and doesn't drain the battery and takes 2-3 extra seconds to wake.
    Other thing you can do is set max CPU power to 99% this way you will not use Intel Turbo boost, thus CPU will be locked to max 2.2GHz instead of bursting to 3.4GHz.
    2016-03-05T02:22:20+00:00
    I tried the Win-Ctrl-Shift-B thing today, for the first time.  It woke it up out of sleep perfectly.
    So I guess this is some sort of solution for me - except when the keyboard is not nearby.
