2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-04T11:41:19+00:00
    I am using an SP4 since December 2015 currently on Version 10.0.10586 Build 10586. Ever since I start using SP4, most of the time the machine does not wake after sleep. I am always expecting one of these heavy patches released every now and then will fix this issue but no.
    Am I missing something here, is there a solution to this? I am finding a lot of posts similar to this but cannot see a proper solution to this.
    2016-03-04T12:31:48+00:00
    Hi!
    This has unfortunately not helped.
    Waiting for a swap unit of the surface now (for heatproblems) let's see if that helps
    2016-03-04T13:02:11+00:00
    Nope. Not fixed.
    Fully patched, updated, locked and loaded.
    SP4 i5/8/256. Most of the time waking from sleep either is a short experience (as it's burned through the battery in the laptop bag) or swear inducing (as it's black display force reboot time.)
    I am sure development has isolated and fixed a SYMPTOM of the problem, but not the actual root cause.
    And I'm now seven days outside my return window.
    2016-03-04T17:20:16+00:00
    Just in case any Microsoft reps are reading this thread - I have this issue too.
    I DIDN'T have it until the last round of firmware updates, mid-February.  That's when it STARTED.  Up until that point, my Surface Pro 4 was issue-free.
    I've had to disable sleep wherever possible and hibernate instead.  It works, but it's a bit of a pain to have to do that on a TABLET computer.
    All my firmware drivers are up-to-date (I've checked the version numbers against what's listed above).
    I've only just now learned of the Win-Ctrl-Shift-B trick.  I'll try that next...
    i7 16GB 256SDD SP4 - The win+ctrl+shift+B didn't work for me.  Still have to do the 30 second power hold and restart to get the screen back.
