2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-04T00:40:20+00:00
    Yes - the 2/17 update seems to have fixed the problem.  The issue is that for some people (me for example) the update failed to install first time (no warning of course).
    Microsoft are aware of this and have posted a fix to fix the fix!  See their note below:
    • We are aware of a limited number of customers for whom the 2/17 Surface firmware updates did not properly install. Our engineering team has provided simple instructions on our support page athttp://support.microsoft.com/kb/3145770!\[\](https://www.microsoft.com/surface/assets/img/external.png) for checking the status of the installation and manually completing in cases where this is necessary.
    • If you update the operating system on your Surface, this will clear your existing update history.
    • Firmware updates cannot be uninstalled or reverted to an earlier version.
    This is usual MS double talk  i.e. Limit number = Many  and Simple = Beyond usual home user capability
    Good luck!
    The 2/17 update did not fix the problem for me.  Also the "fix to fix the fix" was of no use to me.  I have nothing in Device Manager that's listed as failed.  Everything installed correctly, and I even looked at the firmware versions to verify they match the versions listed in the "fix to fix the fix" article.  Everything matched.  I still have the problem.
    2016-03-04T01:17:41+00:00
    I have made sure I have all the updates and still have the same problem. I have checked the driver versions also.
    Frustrated here!  Please fix!
    2016-03-04T01:33:26+00:00
    Just in case any Microsoft reps are reading this thread - I have this issue too.
    I DIDN'T have it until the last round of firmware updates, mid-February.  That's when it STARTED.  Up until that point, my Surface Pro 4 was issue-free.
    I've had to disable sleep wherever possible and hibernate instead.  It works, but it's a bit of a pain to have to do that on a TABLET computer.
    All my firmware drivers are up-to-date (I've checked the version numbers against what's listed above).
    I've only just now learned of the Win-Ctrl-Shift-B trick.  I'll try that next...
    2016-03-04T02:08:14+00:00
    Well, the Acer Aspire V5 does not have a sleep problem. It is doing a classic sleep and does it perfectly, with the same Intel chipset.
    I do wish Microsoft hadn't tried to be so clever and had put off all this disconnected standby stuff until it worked properly, or at least given us an option of the classic sleep.
