2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-03T17:03:13+00:00
    I'm not sure if this is already well-known, but Windows logo key +Ctrl+Shift+B turns my screen back on every time this happens.
    I'll try this to see if it's a 100% effective of me. But, this is sold as a tablet as well and the keyboard is an additional accessory. I often use it without a keyboard.
    Join in: #SurfacePro4 #nowake
    Ah, good point. My keyboard is never far away from my surface so the shortcut ends up working perfectly for me. But the surface pro is marketed as a tablet-first hybrid, so I agree that microsoft still needs to fix the damn problem ASAP.
    P.S.
    You can (sorta) test it now, your screen should turn off and on again.
    2016-03-03T18:23:10+00:00
    Hi All,
    Josh
    Josh,
    I own a surface pro 4 and I have been having the same problem, most of the time I can hit the good old ctr, alt, del and the screen will turn on so I can enter my password. I have installed the update that is "supposed" to fix this issue and it hasn't. So my question for you is have they actually fixed the problem and if so where can I find this mythical solution.. Leave it to microcrap to release a product full of bugs, I should have known better and just purchased a mac. I do really like the surface pro 4, it was a great idea but if there is no quick solution to this expensive paper weight I will definitely be returning it and taking my business to apple never to return. You know bill gates is supposed to be this software genus but windows since the day it was born has always had problems... So in hindsight the only good thing to come from bill gates was windows a design he stole. Microsoft's ideas are great but they are always released too soon creating software problems that they constantly try to fix through updates until they release a new version promised to be better that end up having more software problems... what a joke and how they are still in business is beyond me.... sooo all that being said. any fix to the latest software problem or am I taking this piece of **** back to Microsoft and heading to apple?
    2016-03-03T20:10:27+00:00
    FYI Bill Gates left MIcrosoft almost 10 years ago
    2016-03-03T21:56:14+00:00
    Yes I know this, and there has been no difference from the time Microsoft began till now. I think it's just going to be the fact that Microsoft Windows operating system should have never hit the floor because I really just don't think that there is any fixing it. The only improvement I've seen over the years is that it's starting to look and work more like Apple which would make sense in regard to Microsoft stealing other peoples designs it's just that they're doing it slowly so it's not as noticeable lol.
