2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-03T01:22:42+00:00
    I thought I was safe and then ...
    I have all settings (that I know) avoiding sleep and choosing hibernate.  But despite this, just now, after about 5 minutes no activity the Surface Pro 4 (i5, 8GB, 256GB) put itself into connected standby and would not come back to life, until the power button was pressed for 20 seconds for a reset.  This occurred with no keyboard attached and not plugged in.
    It is pretty frustrating and would have been very annoying if I had left the Surface with open and half-completed work.
    I have bought an Acer Aspire V5 for my grandson and it has the same chipset.  It will be interesting to see how it copes with sleep ....  I'll report back, and grit my teeth about the Surface Pro.![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=b27ac645-0030-4933-8060-51a46559547f)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=eb108f72-8f80-40b6-8873-e8abf4704bca)![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=ec1c8441-f448-4ee2-bc1f-a746844a8316)
    2016-03-03T05:28:58+00:00
    All:
    As of March 2, 2016 I continue to experience the problem described here. Specifically after returning from sleep I can see the camera activate and Windows Hello logs me in. However, the screen does not display.
    Here is what I've found:
    • I frequently use an external plugged directly into the SP4 using the Extend option. When coming out of sleep mode I found that if I press the Windows-P, then home button, then Enter my SP4 internal display will come on.
    For some reason the problem appears to be Windows not activating the internal display but, theoretically, having trouble with where to present the image. Resetting presentation mode back to internal monitor seems to resolve the issue. My system appears to be stuck in extended mode because I can press the up arrow twice to get the same results. The problem even occurs if I manually perform these steps before disconnecting the external monitor.
    I would be curios to know if others have a similar experience in that they are using an external monitor at some point in the process.
    I suspect this can be resolved with an update from Microsoft once they get a handle on the cause of the problem.
    2016-03-03T05:31:59+00:00
    None of this worked for me all the updates are installed and the driver versions check out with what is listed here.  SP4...
    https://support.microsoft.com/en-us/kb/3145770
    Still won't turn on the screen after a wakeup from stand by.
    Sincerely frustrated here.
    2016-03-03T05:44:38+00:00
    All:
    I've never had an external display connected to my SP4.  Mine just doesn't wake back up after going to sleep.  The camera doesn't activate for Windows Hello to log me in.  Nothing happens.  I have to hold the power button for 30 seconds, then release it and press it again to start my SP4 working again.  The only thing that seems to work for me is to change all the power options (for the button, closing the cover, etc) to Hibernate instead of Sleep.  When set to Hibernate everything works great - so that's where I'm leaving the settings until they can get things fixed.
