2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-02T14:01:22+00:00
    Not clear if this March 1st update include any fix for our issue, the only mentioned bootup improvement is here:
    Improved reliability in numerous areas, including OS and Windows Update installation, startup, installing and configuring Windows for the first time, authentication, resuming from hibernation, shutdown, kernel, Start menu, storage, Windows Hello, display modes, Miracast, AppLocker, Internet Explorer 11, Microsoft Edge browser, network connectivity and discovery, and File Explorer.
    Full detail liste here:http://windows.microsoft.com/en-us/windows-10/update-history-windows-10
    I'm gonna try it as well.
    2016-03-02T14:19:33+00:00
    Post 2/17 updates (no issues in device manager and  all version numbers correct), I'm now experiencing the blank screen on wakeup while plugged in and an extended sleep period, aka overnite. The 3-finger salute brings it back 95% of the time but had to do a forced shutdown a couple of times.
    When on battery no wake problems thus far, strange indeed.......
    workaround is set to hibernate instead of sleep while plugged in
    2016-03-02T15:04:13+00:00
    FYI for all, the 3/1 windows updates did not fix the problem for me.
    Join in: #SurfacePro4 #nowake
    2016-03-02T17:23:50+00:00
    I had the problem and could not use sleep at all.  I used the Hibernate option to get around the problem.  That worked well enough that I will consider using it permanently.  I really don't mind the extra few seconds to come out of hibernate.
    But I tried the sleep again today after the 3/1 update.  I has worked every time for me so far.  tried short sleep times and long ones.  No heat.  No problem coming out of sleep mode.
    Very strange that the update fixed this for me but not for others. I really had the problem.  could not come out of sleep at all.  now it is working fine.
