2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-02T01:54:29+00:00
    Well...removing the printer drivers didn't help either.  Checked it about 3 hours and 45 minutes later, and it wouldn't wake up...again.  Had to do the power button for 30 seconds trick again.  Battery also dropped in that time from 80% to 45%, and my SP4 was kinda warm.  I've also noticed that when it goes into this "won't wake up" mode and I have to do the power button thing, it also is stuck in tablet mode when it comes back on until I remove and reconnect the keyboard.
    Guess I'll be changing the settings back to Hibernate instead of Sleep until they can get this fixed.  That's the only thing that seems to work well for me.  I have zero issues with putting it into hibernate mode and then waking it up later.  I'm a Mac guy, and I actually really like this SP4 and Windows 10.
    2016-03-02T03:30:15+00:00
    I wouldn't stress over trying to solve for printer drivers. My device is out of box except for current Windows Updates, including March 1 update. I have the sleep issue repeatedly. Many others are in the same boat. Its a fundamental problem with the device and OS.
    2016-03-02T04:03:49+00:00
    That's one thing that actually worked pretty good(printer);
    As for update.. at least we got one!! Normally were left in the cold
    Hopefully soon sleep will rock..:
    2016-03-02T07:37:07+00:00
    OK...today's updates didn't help.  After going to sleep for about an hour I couldn't get it to wake up.  Had to do the power button for 30 secs trick.
    Going to remove the printer to see if that makes a difference.  Have Canon printers here.
    I don't have my surface yet, but will be picking it up tomorrow.  The wake and sleep issue is a common Windows 10 issue.  I used the fix below and resolved the issue on my i7 notebook. I thought it may be worth a try on the surface.
    My notebook would not wake up, and it was absolutely driving me crazy. This is what fixed it for me.
    1:  In settings assign "sleep" to the power button for plug and on battery, assign "do nothing" for all other options.
    2:  Uncheck "fast startup". *no substantial difference in speed whatsoever.
    3:  Save settings.
    4:  Restart
    5:  Use the power button only for sleep and wake up, do not do it from power in the start menu!.
    This fix worked perfectly for me, no more holding down the power button for 30 sec and all that nonsense, basically a restart!
    Please let be know if it works for your surface.
