2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-01T21:03:48+00:00
    I can't answer the question about awaking from Sleep because I disable Sleep and only use Hibernate. My usage patterns are such that Hibernate works better for me than Sleep however I did use it for a few day during the problems. I don't recall there being a problem waking after Sleep not that my system ever got hot.
    I though I had made it clear in my first post that this was just a boot problem (after shutdown or hibernate only) so I don't know how it got into the Sleep problems area. I followed a lot of the recommendations offered here with no improvement. I was reluctant to install 14271 because of a reported problem with BSOD and Hibernate but it did appear to fix MY problem. I hope everyone else can find the magic cure.
    2016-03-01T21:07:04+00:00
    Just curious - did you let Windows install the drivers, or did you download from the Brother site and install those?
    I had initially installed the drivers and the related support software using the Brother disc that came with the printer.  There were no warnings about unsigned drivers. I removed the printer from devices and also uninstalled the related software from Apps. That cleared the sleep problem. I then tried the simpler installation using the "Add Printer" dialog. That installed the Microsoft driver and the sleep problem reappeared. I removed the printer and the sleep problem was cleared again.
    I still have some weird behavior. I have the Power and Sleep setting to disable the power button and only sleep on closing the cover. Now if you click the Sleep option in the Start Menu > Power menu, the tablet immediately does a soft restart asking for log-in. Earlier I had found a setting to remove sleep from the Power menu options but I cannot find that anymore.
    My Surface just installed the latest update. Maybe that will change things again.
    2016-03-01T21:41:22+00:00
    OK...today's updates didn't help.  After going to sleep for about an hour I couldn't get it to wake up.  Had to do the power button for 30 secs trick.
    Going to remove the printer to see if that makes a difference.  Have Canon printers here.
    2016-03-01T22:04:38+00:00
    Yup, didn't work for me either.
