2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-01T20:24:54+00:00
    Just curious - did you let Windows install the drivers, or did you download from the Brother site and install those?
    2016-03-01T20:26:32+00:00
    I still have this issue (SP 4, Win 10, 64) even though I have all updates from Feb 17/18. All updates are completed (along with restarts).
    What is the specific update that was meant to fix this issue?
    Tim
    2016-03-01T20:29:17+00:00
    Josh,
    Thanks for the update but I'm still having the issue. I checked and all updates are installed. Could you tell me the KB number for the update so I can verified it installed?
    2016-03-01T20:31:06+00:00
    My SP4 just showed an update KB3140743 - Cumulative Update for Windows 10 Version 1511 and Windows Server 2016 Technical Preview 4: March 1, 2016.  Downloading now to see what (if anything) it helps with.
