2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-01T18:32:13+00:00
    Any other ideas?
    Sadly after many restarts, and manually installing the updates using the .msi file as noted above (though device manager had the current drivers and no yellow triangle, but I manually reinstalled them just in case), I still have the 4 updates saying require restart. The Surface Pro 4 rarely now awakes from sleep, so have to do the hold power for 30 seconds etc each time.![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=f23812ca-0561-4d92-80cf-9dd4560d1118)
    2016-03-01T19:25:01+00:00
    Hi All,
    I was experiencing an almost identical problem with my newly purchased Surface pro 4. Most of the time it would require a hard reset by holding down the power button 30s  in order to restart after sleep. The 2/17 update is installed. I visited our local MS Store for help and they concluded that this particular Surface was faulty and exchanged it for a new unit. However, on reinstalling the software and drivers I had been using, the problem returned. I determined that the culprit was the Microsoft driver for my Brother L2700DW printer.  The printer is installed to be shared and accessible through a wired TCP/IP network. When the driver is installed the Surface Pro 4 fails to recover from sleep most of the time. This behavior is completely reproducible.  I have no way of knowing how generic this behavior is to other drivers for Brother printers. This instance should be reported to Microsoft for correction.
    Regards
    2016-03-01T19:37:54+00:00
    No Brother print drivers installed on mine, and I have the problem - so I don't think it's exclusively related to Brother print drivers.
    2016-03-01T20:08:58+00:00
    I did not think I was suggesting that this driver was the only possible cause. However my experience does suggest that if you are having this problem it might be useful to try experimentally uninstalling other software you have running, particularly drivers, and see if they could be the culprit.
