2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-03-01T14:25:19+00:00
    I update firmware up to date already,but this issue not disappear :(
    2016-03-01T14:56:44+00:00
    looking at powercfg I see most of the sleep states are disabled.. I could be wrong but if the developers intentionally did this , then we just have to wait for the upcoming updates. I'm just going to shutdown every go.. sleep does work but when I get hit by this issue every so often I spend more time shutting down rather than just shutting down
    business aspect what this machine offers I need so I guess ill have to suck it up! until they release updates.
    (if I wanted stable I guess surface pro 3 should of been purchased)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=c15524c2-5fbe-4559-89c8-7cecbe10f87a)
    2016-03-01T15:43:45+00:00
    Still having the issue after the update. You are completely wrong.
    2016-03-01T17:44:32+00:00
    Same here - completely unacceptable
