2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-29T21:12:31+00:00
    After I installed Insider Build 14271 last week, the problem has gone away and the system starts normally every time!
    2016-02-29T21:37:49+00:00
    In looking at what that build fixes, it doesn't mention our issues.  Also seems surprising given that it is for ALL Win 10, and most others with Win 10 don't have our Surface issues.  But interesting nonetheless.  I would hope if this is the case that MSFT will push it out for all.
    When you say it is fixed, does that include now not getting very warm during Sleep?
    2016-02-29T22:34:42+00:00
    Gordon, any thoughts on the running hot issue when it is the host usb driver or program that is taking up 75%? When I'm sleeping hot, that seems to be the culprit. I've never seen One Note of Skype doing it, but then I don't keep those open either.  But I don't think it is possible to do anything to that USB thing....and it will run hot in sleep even if undocked, so no USB in it.  I haven't yet checked a sleep study undocked though.
    I haven't noticed anything with "USB" in its title. I have definitely wondered if Edge and OneNote were false positives - that there was something system-level was going on, and it just happened to be occurring in those processes so those processes got the blame.
    2016-02-29T23:03:23+00:00
    I checked my installed history. The release updated on 2-17-2016 completed successfully. I have turn on and shut down the Surface 4 many times since then. But the problem still exist sporadically.
    Help.
    This happens when I was working. Could not get to my notes needed for the meeting.
    Please help fix this.
    Thank you much
