2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-29T18:16:43+00:00
    This update did NOT fix my problem - Windows Surface Pro 4 still does not wake up from sleep if left in sleep for more than a few minutes... this is unacceptable!!!
    2016-02-29T18:20:42+00:00
      I've bene living with the update now since it came out. I had the black screen on wake problem, and the running hot while sleeping problem. In general, this has been fixed, but not 100%. I do not quite yet trust it enough to pack it into a bag and get on a plane without first hibernating it or shutting it down. I do trust it enough to grab it and go to a coffee shop or to work.
      Here is what I've found: First, about one in 5 times, when I open the keyboard the keyboard lights come on but the screen remains black. When this happens, a quick press of the power button turns off the keyboard lights, and a second quick press turns everything back on again, including the screen. I have not had to do a single hard reset since the update, which is a big change!
      As far as running hot. The sleep study thing (which I didn't know about until recently) has proved very helpful. The culprits are usually "Microsoft Skype", "OneNote", and "Edge". All three of those I kind-a depend on. I'm not sure how they are preventing the machine from sleeping, but if I'm just using the machine normally and the fan comes on, it is often one of these that is running flat out on a single CPU/thread. Though sleep study has never mentioned it, I've seen other components at 100% - like the service host, or the compressed memory manager.
      So, even for me, though the thing is behaving significantly better, there is still some work to do. But some of it seems like windows 10 optimization, not just SP4 optimization.
      Cheers,
        Gordon.
    2016-02-29T20:03:30+00:00
    All,
    I've returned my SP4. Good luck. I'm heading back to my mac. I'll be watching from afar waiting for this tech to mature.
    S.
    2016-02-29T20:49:21+00:00
    Gordon, any thoughts on the running hot issue when it is the host usb driver or program that is taking up 75%? When I'm sleeping hot, that seems to be the culprit. I've never seen One Note of Skype doing it, but then I don't keep those open either.  But I don't think it is possible to do anything to that USB thing....and it will run hot in sleep even if undocked, so no USB in it.  I haven't yet checked a sleep study undocked though.
