2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-11-23T20:48:09+00:00
    New info: I exchanged the surface dock for a new one. Same blinking problem with screen when surface dock is attached to the surface pro 4. Wondering if I now have a bad Surface Pro 4. Should I exchange the surface?
    2015-11-23T20:51:23+00:00
    I have also been having the same issue.
    It only began a couple days ago for me but now keeps happening.
    The only solution that I have found is to put the device to sleep by Power > Sleep as opposed to hitting the top button or just shutting the type cover.
    It is a drag though... I often forget and hit the button and then have trouble waking it up.
    I hope this gets fixed soon!
    2015-11-24T05:30:02+00:00
    I asked Microsoft to replace the device, and it did - hopefully if enough people do it it will get resolved - losing money wakes up the right people....
    2015-11-24T06:03:01+00:00
    Thanks, Gordon, looks like this is working for me. Do you get a pop up message at the lower right corner 'Display drive stop working but recovered'? I got mind quite frequent especially using Edge to surf the web.
