2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-29T16:15:05+00:00
    I have this update installed and confirmed since 2/18/16 but I didn't start experiencing this problem until 2/24/16 so for about a week after the update it worked fine. I got my SP4 on 2/17/16 so I can't speak to any potential problems before the update. Any help?
    2016-02-29T16:48:20+00:00
    My SP4 was working great until the update on 17/2/2016. Now I have problems with waking the Surface from sleep, both with and without being plugged in. The machine is running hot and the battery life today went from 60% to 6% in about 20 minutes.
    Can I uninstall the update as everything was fine before this was downloaded?
    2016-02-29T17:25:29+00:00
    Yes, through system restore. From the search bar search for "restore" and click on the "create system restore point control panel" option. Select restore my system and choose a point from before the update.
    2016-02-29T17:30:02+00:00
    Please tweet for me.  I don't use twitter and I am very disappointed with my Surface Pro 4.  It's been replace once already and I still have the issue of not waking up after sleep.
