2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-28T22:38:00+00:00
    Is anyone still having the same problem after the feb 17 update?
    2016-02-28T22:48:19+00:00
    Hoping that is sarcasm :)
    the last couple hundred posts are about the update not working.
    2016-02-28T23:01:31+00:00
    Yes I still have it, may even have gotten worse
    2016-02-28T23:02:17+00:00
    Thanks.  This fix works for me every time, opening/closing the lid  a second time.
    VERY GOOD.
    Thanks.
    This "fix" of opening and closing the lid twice.  It may wake up the SP4 from Sleep.  But during Sleep, isn't it still running hot? I'm bothered by it being hot for too long, and hence prefer hibernate where it is cold.  Has anyone found that the SP4 IS NOT HOT during Sleep, whether it wakes or not?
