2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-28T14:17:58+00:00
    This situation is ridiculous and the 2/17 update does not resolve this issue
    2016-02-28T14:39:39+00:00
    yeah.. over here I was finally hit by the "all battery life drained while in sleep"..
    looking at the situation as a developer myself this is good stuff to go through(its boring when a system runs correctly)but given this is a work machine for a company I cant be hacking on it.
    what is my boss going to say if I bring it in to work saying its a brick because I was doing Microsoft employees job!
    looking at things all of these bugs need to go into the preview build and if developers wants a rush of bricking their surface and then recovering thru ISO then so be it.. _stable_ release means _stable_ , that means business people have the comfort knowing sh*ts just going to work, and they don't have the embarrassing surprise at the conference table or when they get home and have loads of work flow to go thru.
    2016-02-28T17:44:58+00:00
    I have a feeling some MS employees including Panos like to see MS goes bankrupt. They create all the bugs, poor software on purpose. I can see MS reputation is getting worse. Eventually, there will two big companies left,  Apple and Google.
    2016-02-28T19:46:39+00:00
    that sucks.. its like those investors that invest in a company to have fail(jcpenny was in that boat).
    as for the MS developers whatever they have going on in there for revision control needs to be a little bit tighter. if you introduce a BUG you go back and fix it. no code gets pushed upstream until fully tested and signed off(this revision looks like they hurried everything upstream with no signatures)
