2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-27T17:16:29+00:00
    not sure how to reply.. so Ill reply to my own thread..
    anyways I was able to start the ./remote.exe debugger
    still a novice to this(Linux I would of ssh then cat > /filelocation) to extract info.);
    with ./remote.exe will see if I can grab some info but for now here is a snapshot from tasklist
    as I was able to get the black screen of death(pressing power button brought the lockscreen in of which is hiding behind the blackness)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=b677f748-5fb8-43dd-a7bc-a7d238d96a87)
    2016-02-27T20:59:17+00:00
    Hi All,
    Josh
    My surface pro 4 installs updates automatically. I have checked all updates are installed, and the system is up to date. Still, the same problem with the screen not waking up from sleep persists, and is very annoying. I am thinking of using the warranty to send this machine back.
    2016-02-27T23:02:49+00:00
    I'm thinking we need to light up social media. From Panos' blog:
    "And feedback from our customers is really important to the team and to me personally. I read the blogs, I read the comments, I read social media, I read the forums…and so does the team."
    Retweet: this and/or tweet yourself with hashtags #SurfacePro4 #nowake.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=c1eb21e7-8a88-4796-836d-65509757acc9)
    2016-02-27T23:37:38+00:00
    Added to your hashtag! Brilliant move.
    "Buyers remorse! Major issues with Surface Pro 4 @Microsoft @surface #nowake #SurfacePro4"
