2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-27T04:20:10+00:00
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=445852bf-1d7e-4604-a36b-41fbb58b6844)
    UEFI is installed and I still have the wake problem. I set it to hibernate with the type cover attached, closing lid. I notice some of you have success with hibernation, not me so far. I will change it back to sleep as it was statistically better at waking.
    Unfortunately I have a non-appearing mouse cursor when it wakes also, and all I have found is a restart will bring the mice back (this is outlined in a different thread), so trying back to sleep (if it goes to hibernate after a while that is ok, it was doing that anyway).
    I am getting tired of all the problems I am having unfortunately.
    2016-02-27T05:18:33+00:00
    Hi Josh & Microsoft Surface team,
    Here's a video showing the Surface Pro 4 Sleep Issue after 2/17/2016 update.
    VIDEO: Surface Pro 4 Sleep issue:
    https://www.youtube.com/watch?v=_Lg0fI9Wkxo
    This also shows the workaround of closing/opening the lid a second time to make it work.
    Hopefully this helps you troubleshoot!
    2016-02-27T05:47:57+00:00
    Nice video.. was able to recreate this issue with the info from this video.. power plugged in didn't fire off.. plugging in USB mouse did.
    My log files point to MTConfig
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=57e65fdf-1e27-4670-ab01-7f342ed5162d)
    2016-02-27T11:38:16+00:00
    Thanks Josh
    It's *really* good to get some useful input from the team!
    Unfortunately I also have no warnings in device Manager and still have a range of sleep problems. My Firewmare.Surface UEFI driver date is 29/01/2016 and ver 104.1085.768.0 after installing latest updates.
    Steve
