2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-11-23T18:56:02+00:00
    I am having this exact same issue, for what it's worth (SP4 i5 8GB RAM 256GB SSD). Happens most often when I undock my SP4 from the Surface dock when its asleep, I have a better than 75% chance it won't wake up once undocked which is a real pain as I usually find out when I get to the meeting I want to take notes in. The problem seems worse since TH2 installed on 11/18.
    2015-11-23T19:01:56+00:00
    No statements about lock screen not responding. Only says hardware error.
    2015-11-23T19:22:09+00:00
    I can replicate the exact same problem, but I have never enabled "Hello"
    2015-11-23T19:53:49+00:00
    I got the same problem, no matter enabled or disabled "Hello".
