2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-26T23:35:41+00:00
    Josh, thanks for writing.  I would like to see if this helps ANYONE??  I have no exclamation marks on the firmware.  I don't use sleep beyond 120 minutes,  and thus with Hibernate it wakes, albeit imperfectly as it just did, requiring a restart.  But it is clear to me when Sleep is not working: IT IS VERY WARM during sleep, and cools when it shifts to hibernate.  This needs a fix!!
    2016-02-26T23:42:05+00:00
    I have the sleep issue and no exclamation marks.
    2016-02-26T23:42:12+00:00
    I just bought my SP4 last Sunday and was having the troubles with sleep mode.  I completed the 2/17/16 earlier this week and just switch back to Sleep from hibernate this morning and so far so good today.  I just followed the steps you outlined and I do not have any exclamation marks so it appears the 2/17/16 update installed properly.  I hope this really does fix the problem as I really want to like this device.
    Thanks Josh!
    2016-02-26T23:43:39+00:00
    I'm glad that someone at Microsoft is looking.
    I'm very very disappointed at my Surface 4 purchase at this point. My life is nothing but meetings, and having to hard restart this device 3 or 4 times a meeting has been killing me. To add insult to injury, as a Microsoft CAMSA customer, we standardize on O365, and now my OneDrive Sync and Office Sync has been corrupted causing office apps to fail!
    I know that Microsoft has a monthly update release schedule now, but please send us an update ASAP! If this doesn't get resolved shortly, I'm going to do everything in my power to return the device (I've been holding onto hope for 3 months).
