2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-26T19:12:47+00:00
    Dear Josh,
    Even with the newest update, and using the manual update too, my surface pro 4 is still having issues when waking up from closing the typecover. There is no santeria capable to make it wake up.
    What else could be done to make this vanish for good?
    Mateus
    2016-02-26T19:18:16+00:00
    Hey Microsoft, How about a prize for the 1000th post on this mega thread!?
    if anything it will be the one millionth, and the prize ... an individualised update to fix it, just for them.
    2016-02-26T20:30:56+00:00
    I just got my Surface Pro 4 a couple days ago on February 24.  Worked great on the 24th.  Installed all updates with no problems.  On the 25th (yesterday) I went to use it, and it wouldn't come on.  I Googled and found this (and many other things) about the failure to wake from sleep.  I was able to get it going by doing the power button for 30 seconds, releasing it, then pressing it again.  Next time it went to sleep I couldn't wake it again.  The February 17 update did NOT fix the issue.  My "fix" that seems to be working so far is that I changed the settings for it to hibernate instead of sleep.  It takes it a few more seconds to get going from hibernate, but so far I haven't had it fail to wake up since changing it to hibernate instead of sleep.
    Other than that oddity I haven't had any problems with it so far.  I like it a lot, and I've been a "Mac" for many years.
    2016-02-26T21:41:12+00:00
    Screw this, after update to the most recent firmware (2/17/2016), it DID NOT solve the issue. In fact, the issue becomes even MORE frequent!! before the update, it was roughly happened 1 in 5 times when i try to wake up my surface pro 4 from sleep. Now it is nearly 1 in 2 time!! HEY MICROSOFT, stop trying to fix because you will never fix the issue, and i believe lawsuit will come hunting you guys VERY SOON!
