2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-26T16:51:53+00:00
    I am returning my Surface Pro 4, don't want to risk and wait months for Microsoft to even acknowledge the problem, let alone fix it. Unacceptable for a $1,600 device. At least Apple just works.
    2016-02-26T17:43:00+00:00
    I am assuming a replacement will not help since this seems to be a software issue, I am eligle to get a replacement but not sure if that will help?
    I have reached out to someone in Microsoft who will try to get the right folks to respond to this thread. Hopefully someone will listen.
    2016-02-26T18:07:37+00:00
    i have the exact same isses- 2/26/16, all MS updates are installed. The unit is 2 days old, 50% of the time does not wake up from sleep, or should i say the display fails to appear.
    I changed the settings to hibernate from sleep so the unit works as it should.
    Is MS releasing an update for this? seems like almost 4 months into this and the updates didnt help?
    2016-02-26T18:59:44+00:00
    Same issue here. Updates done and restarted many times. The 2/17 firmware update DOES NOT fix this problem. I tried disabling "WiFi stays connected while asleep" for both external power and battery power; so far so good after 4 or 5 sleep cycles. I'm crossing my fingers that this fixes the issue.
    Moderators, merging so many threads that you have over 1000 replies is a VERY bad idea. Nobody is going to read all of these replies. You should have just closed most threads and put a link to this one. It sure appears that you're mainly trying to make it look like there aren't many people having problems with this "very problematic" device.
    EDITED TO ADD:  No go, it still fails to wake up sometimes. I am so sorry I believed Microsoft when they said they were going to fix this thing. In should have returned it while I still could.
