2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-26T14:28:42+00:00
    So my wake up issues are only getting worse and my battery is horrible now.
    Before this update it wouldn't wake up maybe once or twice in a day. I use mine on the go a lot so it is in and out of my bag all day. I may put it to sleep and wake it up 10 - 12 times in one day.
    I use to be able to have a productive day with what little battery life I had, now this is just pathetic.
    I have tried using all settings recommended above. all of the settings are set to sleep, fast start up is turned off, if the surface is asleep nothing is connected wifi, blutooth, etc. and I still have to find a plug after just 3-4 hours.
    2 nights in a row now I have put it to sleep by closing the type cover, the only way I put it to sleep, both nights my battery was above 90% the next morning when I get it out, the battery is dead.
    I am really getting frustrated with this. I had a SP3 and never had any of these issues, this is just unacceptable for a $1k+ product. Unfortunately for me I purchased mine on release day from best buy, and I am just now having this many issues. I was able to deal with the occasional soft reset, annoying but manageable, but the amount of issues now is really affecting my work day.
    I have an i5 256, other than this annoying issue and the rear camera problems, which luckily I did not purchase a computer for a camera, I do not seem to have any of the other issues that people are having.
    Please, at least undo what you have done MS. Seems the recent update has created more issues that resolutions.
    2016-02-26T14:53:00+00:00
    Tested again overnight. I turned off "password required to wake", disconnected my type cover, set wifi to off when sleeping, set to never hibernate, turned off "Fast Start" and changed all my power setting to sleep. Put it to sleep with 100% battery at around 10:30pm and tried to turn it on this morning around 7:30am but nope, black screen of death. Did a hard reset to turn it back on and my battery is down to 54% so it's draining at about 5% per hour. I'm giving up at this point till I hear something from Microsoft (fat chance) and setting everything back to hibernate. Good luck to everyone.
    2016-02-26T15:20:41+00:00
    Did the same here !!
    Put it into sleep at 60% left battery.
    This morning I had the battery icon on screen, completely depleted, so at least I did not had to hard reset it I guess. but had to have recharged.
    What is frustrating is that Microsoft claims that the issue is fixed when it is not, and they haven't done any new acknowledgement of the issue since Feb Update.
    Good luck everyone indeed...
    2016-02-26T15:44:34+00:00
    so disabling the wakeup lock wont fix it for you..
    one thing I noticed as I was testing is I woke and slept the machine numerous times with the typepad(no power button, or windows switch)
    during those sleep/wakeups I would see a different result with the keyboard to touching the screen to pressing the power button(very unstable, almost as if multiple functions are being called(race condition));
    when you get ur black screen of death can you wake and sleep numerous times until it actually works? using the keypad to wake/sleep?
    over here sleep seems stable when I use the type cover to initiate the sleep. If I let the machine sit and go to sleep by adjusting the time to 1min trying to wakeup with the keyboard fails giving me only lights on the keypad. pressing the power button wakes up the machine.
    now after having a dead keypad and having to press the power button I see this:
    (unable to type until I physically disconnect the typepad and reconnect);
    looks like our USB typepad BUG..:
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=a288d6e9-e135-4e53-a846-7d638c4e24be)
