2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-26T02:55:08+00:00
    I wonder, why the tech website did not post problems on 2/17/2016 firmware update. Do they get pay by Microsoft to cover up these problems??????
    2016-02-26T03:02:51+00:00
    Attached image of power management.. depending on the workload ill suspend/wake every hour or every two hours, at home randomly just like a phone. When testing this I was suspending simultaneously for 10mins straight.
    seems like I'm past the 30hrs.. will let it run. Then if confident will try to recreate the regression..
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=9906fbe2-3708-4fa1-9ab4-6a9244b843ca)
    2016-02-26T03:07:49+00:00
    Forgot to answer.. putting to sleep I'm closing the type pad.  was using power button but then said to myself this thing is not an RC release this should work stable so started closing the type pad like it was intended.
    2016-02-26T03:47:33+00:00
    Dear Microsoft,
    Many people demonstrated their willingness to adopt your product as the marketed replacement for a laptop. Unfortunately, your product cannot handle the simple task of waking up when pressing the power button. These machines are expensive for individuals and businesses alike, and we have made recommendations to purchase these devices, and we must deal with the backlash of recommending products that cannot perform a fundamental function that even a $100 tablet can do.
    Now, even though we have shown support for Microsoft, Microsoft cannot even respond to this thread which has so many comments. From a basic customer service standpoint, you should: 1. Acknowledge the problem. 2. Explain that you are working on a solution. 3. Give daily updates. Is it really that difficult to maintain this relationship with your customers? Come on Microsoft, it is basic customer service.
    Please respond, Microsoft. Please make us feel like we did not waste over $1,000.
