2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-26T00:54:37+00:00
    Uptime here is around 25hrs.. suspend works good but the whole after x amount of hours it goes into hibernate is kind of annoying, why not just shutoff right?
    Anyways will see what happens after 30hrs.. so far the onscreen keyboard already jammed but recovered(had no reaction for a min or so).
    Will see..:
    2016-02-26T01:26:59+00:00
    Unfortunately my suggestions didn't work. I have 10 days left in my 30 day return policy. I feel this may be going back to CDW. This purchase was to test this device for recommendation to my Firm of 13 partners and 50 PMs. So close....
    2016-02-26T01:41:43+00:00
    How are you putting it to sleep?  (Power button, Windows Menu, close keyboard cover, etc.)
    And how and how often are you waking it?  (I presume by power button, since you mentioned the onscreen keyboard...)
    Anyway, 25-30 hours is pretty impressive.  I guess we'd need to know when you're hibernating to know if that's really good, though.  It would be good to run the power report (powercfg /sleepstudy) when you're done to see what all happened.
    Intrestingly, there's some decent hunting into the heat issue over on this thread: http://answers.microsoft.com/en-us/surface/forum/surfpro4-surfperf/i5256-surface-pro-4-overheats-and-battery-drains/045497f8-1ece-49b2-aeaa-8aa10994a277 - Like this thread, it's old, with a lot of bad info at the top - you'll need to dig way down in the pages to get to the newer info.
    It's starting to look like all of this is related, even if there are multiple problems...
    2016-02-26T02:50:43+00:00
    Josh, The update doesn't fix this issue...any idea of when another update might be available. All of us who bought the marketing and are using this device for work are having to deal with this daily.  Thanks.
