2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-25T17:30:03+00:00
    After 2 more days of testing I can almost confirm the cover keyboard is causing my sleep issue. I noticed that on the first day.
    Without the cover keyboard I can sleep, wake, hybernate, wifi on background, no battery drain.
    With the cover one I have to use hybernate. I really don't care that much for sleep vs. hybernate but for a $1600 devices I want it to just work. If none of you had the issue I would think I have a faulty cover or device, but that's not the case.
    Have to decide today if I want to return the device. And frankly, with Skylake Macbook Airs just around the corner at 2/3 the cost, don't know why I'm still holding onto the Surface. Microsoft is keeping quiet, no tweets, no acknowledgement no anything...
    2016-02-25T17:55:53+00:00
    Not a stupid question. Leaving it in hibernate is fine and seems to work 100% of the time. Doesn't get hot, no battery drain, etc. I think people complain about the sleep issue because it takes longer to boot up (which seriously isn't that long or a big deal) but it should just work. It seems like such a simple function that is available and works for nearly every other computer. For people who don't know much about computers and experience this issue, I'm sure they hate this (like everyone) and might not know what to do.  I will be switching back to hibernate after I do some more tests.
    Actually I have a type cover, and having it hibernate doesn't work 99.9% of the time now. I now do a full shut down every time, which is silly but its either that or a hard reset via press-and-hold power button.
    2016-02-25T18:02:43+00:00
    I am with you on this one...
    As I have said before, if apple was to put out a device similar to the Surface, and running MacOS instead of iOS, I would definitely jump on it. At least with Apple, you know that the device when coming out of the box would just work (it is then up to you to break it ;)). The key here though is that the basic functions of the 'computer' would work as intended and expected. With all the false advertisement produced by Microsoft, I keep finding myself just hoping and waiting for MSFT to fix the bugs. This is not acceptable at this price point, and for a device made by Microsoft...
    Sadly, it is too late for me to return it, as I have been waiting and hoping for too long.
    Back to my trusty macbook pro. Don't get me wrong, the macbook has its issues as well, and I am not too excited as to where Apple is taking MacOS, but for my day to day, it is still more reliable and useable than the Surface.
    If I close the lid on my macbook, it will go to sleep and won't drain the battery extensively. This is kind of an important feature on a laptop (even more so on a tablet), and shouldn't be that complicated a challenge for Microsoft to fix. I am sure they have a few software engineers that could solve this problem...
    Anyway... the disappointment continues.
    2016-02-25T18:10:14+00:00
    What are your thoughts of the iPad Pro in place of the Surface Pro 4? I am not in design just want a very portable machine to type and run an virtual fitness accountability group from.
