2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-25T03:37:22+00:00
    Over here the machine did the updates but still hit the black screen of death!
    changing fastboot did nothing.. on the contrary if I disable password on wakeup I get a stable result.. even at sleeping for 1:45mins..
    Doing a hard shutoff is not good especially if u have documents.
    Will see the next few hours if I hit this.. if I have time this weekend I can setup ssh or any debugger to grab the offending code, and try to fix, this way I don't have to wait around in limbo
    2016-02-25T03:38:52+00:00
    I did this update and now it just flashes "surface" for one second and then turns back off.  So far I've had this for 3 days and have yet to have it function correctly in the on position.  I was hoping maybe I just got a bad one, and if I returned it and got a new one I'd be ok, but it doesn't look like that is the case.  Does anyones SP4 work?
    I have the SP4 with the i7.  All updates installed, but my sleep function still doesnt work.  Have everything set to hibernate for the time being as a work around.  Takes a few seconds to turn on but not as long as a hard reset.
    2016-02-25T07:27:42+00:00
    Hi All,
    Josh
    Hi Josh,
    Unfortunately, after the recent firmware updates, my Surface pro 4 does not sleep correctly.
    When I open the type cover, the screen does not turn on. The IR camera lights up as if it wants to ID me, the keyboard lights come on but the screen does not.
    A hard reset is required to get the machine to boot (hold the power button for 30 secs)
    In addition to this, the unit loses about 50% battery overnight when it should be asleep or in low power mode.
    I have all the latest updates installed and all necessary reboots performed.
    Thanks in advance for assistance.
    F.
    2016-02-25T07:40:58+00:00
    You might be on to something. I've got exactly the same issue! It was working after using the Surface Platform Installer, untill I plugged it onto my dock. I didn't connect the dots till now!
