2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-24T21:41:55+00:00
    Please see this discussion:
    http://answers.microsoft.com/en-us/surface/forum/surfpro4-surfdrivers/surface-pro-4-startup-problems/8bf5f6d7-f18e-410e-bd6b-8ab7d50d886b
    Thanks for pointing me to the other discussion. I missed it in my search.
    2016-02-24T23:03:41+00:00
    2016-02-25T00:05:47+00:00
    man.. if I wanted these kinds of bugs I would of loaded up a Linux machine with Linus's latest kernel!! then would of started to debug. Anyways positive side on this is, is the machine is still alive when this occurs(unlike total freezes and such). the logs are pointing to:
    MTConfig   (<-----may disable to see, but then again I don't want to risk locking myself out due to no keyboard(s))
    probably why the keypad crapsout and the wakeup is all mangled.. out of 20 suspends I get around 5 or 7 good ones, then the rest is all black; seems random, maybe something with the fingerprint code(hopefully nobody sets that code..:)
    also seeing in the logs something about permissions with a pseudo terminal (pty) normally when things like this occur something is not allow to activate(screen), maybe Microsoft can check their device nodes that are being created, or a policy that doesn't have the correct permission
    other than that great machine for my company! love the pen, atleast that works(!)
    2016-02-25T00:45:15+00:00
    The dock might also be involved in some cases. Last night, I used the Surface Platform Installer to reinstall the new driver, and it seemed to sleep and wake fine the 3-4 times I tried it. Earlier today, when I finally put it into the dock in my office, it wouldn't wake at all.
    I suspect if you let it sleep more than 2 hours, it won't wake.  In the dock, did it sleep for 2 hours?  You might want to try using hibernate instead after 2 hours docked.  Even then, when sleeping for the first 120 mins, it runs warm! But wakes.
