2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-24T17:55:53+00:00
    2016-02-24T18:10:27+00:00
    Dear Josh_F,
    My system is updated with all the fixes released till date. I even checked in the update history -> "System Hardware Update 17-02-2016....Successfully installed on 23-02-2016".
     The problem has not been resolved.The system does not wake up from Sleep. Did it work for others? I am using Microsoft Surface Pro_4
    Regards,
    Amit
    2016-02-24T18:57:42+00:00
    I seem to have more problems with the keyboard attached. Also attaching or disconnecting it when it is sleeping (hibernating) seems to create problems (Bluetooth mice do not work until I restart, sometimes Rotation tile in the Action Center is missing and it does not rotate if just a tablet etc.)
    I find it will wake with the button (and recognise me) if it is just a tablet—whether sleeping or hibernating; then I can attach the keyboard if needed. Of course this is annoying as I have to carry both in my bag unattached and I am worried about the little connection pins getting damaged.
    2016-02-24T19:02:57+00:00
    I have exact the same issue as decribed here...
    It was some time before the feb 17th update but it is almost every time AFTER the feb 17th update!
    This is very bad, because all saved things are lost!
    Is anyone from MS here who will care for the problem?
