2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-24T13:43:13+00:00
    Hello All
    I have the same issue with the new Surface pro 4 and new dock, I had no issues with the SP3 and older dock.
    When undocking and re-docking I lose the connectivity to the 2 monitors. This is happening to multiple Surfaces and docks as I have many.
    Please see this thread of others with the same issue
    http://forums.windowscentral.com/microsoft-surface-pro-4/390829-anyone-else-having-issues-surface-dock-not-working-2-screens.html
    I have 50 units to roll out in my office and this issue is stopping me. Can Microsoft please confirm there is a known issue to them and it is being looked in to. When will an update for the dock or o/s be coming to fix this? I have the most recent updates installed by the way (2/17/2016).
    Regards
    Marc W.
    2016-02-24T13:56:57+00:00
    My fellow early adopters. I may have discovered a solution that seems to address the non-waking screen and poor battery life.
    I've disabled "Fast-Start". Also to extend my battery life I've enable "battery saving mode". Adjusting both settings have increased my battery substantially and has so far remedied the non-waking screen issue. However, I must paint these statements with the caveat that further testing is required.
    I remain optimistic that MS will continue to investment of this tech and hear our voices. They have a unique market with the Surface and it would be tremendously disappointing to ignore these rather disturbing bugs.
    Good luck!
    2016-02-24T14:42:58+00:00
    My Surface Pro 4 was working fine until the Feb. 17 update that was supposed to fix problems I did not have.
    Twice since I updated on Feb. 20 my Surface Pro 4 will not turn on when I push the power button.
    I have held the power button down for the 30 secs and it still will not start.
    The only thing that worked was to hold the volume up and the power button at the same time for 15 secs which got me to the UEFI screen where I push exit and restart.
    The Feb. 17 update apparently caused the problem it was supposed to solve.
    Has anyone else experienced this problem since the Feb. 17 update?
    2016-02-24T16:08:21+00:00
    The "Clean Boot" I was referring to was after going through msconfig to select the Diagnostic Startup as suggested in another support suggestion. It didn't have any effect.
    I have tried the process suggested above and since it didn't specify, I did it from the machine being powered off as well as while logged in. In both cases the machine always ended up at the BIOS/UEFI setup screen.
    In case it is significant, what follows is the Firmware data.
    System UEFI:            104.1085.768
    SAM Controller:           103.1081.260
    Intel Management Engine:          11.0.0.1202
    System Embedded Controller:        103.899.256
    Touch Firmware:        1.51.149.106.4.36
    I can also confirm that the sequence reported by TheCyberKnight is exactly what I am experiencing but it isn't happening occasionally, it is all the time.
    As an additional info -- system Restarts seem to work fine.
