2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-24T10:02:09+00:00
    Mine can't wake from sleep, too. Only keyboard light up, no screen, nothing to do but force it shutdown/restart.
    2/17 update installed.
    2016-02-24T13:12:08+00:00
    Try the following next time you get a blank screen
    Press and hold the Windows key press the P key 4 times and cycle through to (Second screen only)
    Press Enter to select 'No' on the  'Are you sure you only want to use the second screen'
    you may have to swipe the screen up to bring it back but most of the time it brings it back.
    Guessing the Surface display forgets it is a screen and when you do the above it rescan's and detects the attached screens
    Saves having to reboot and loose work! :-)
    2016-02-24T13:18:27+00:00
    Try the below, works for me every time.
    Press and hold the Windows key press the P key 4 times (to cycle through to (Second screen only)
    Glenn
    2016-02-24T13:23:09+00:00
    Try the below
