2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-24T06:45:50+00:00
    The battery thing is interesting.
    I have facial recognition on. When I press the OFF button to turn it to sleep or hibernation without the keyboard attached, it will go black then come back on ... and search for me for a very long time. I wonder whether for some of the battery drain some of you are reporting, it is doing the same - it's actually on searching for you. I have to remember to press the OFF button twice.
    Then sometimes I see this also. Probably not related directly to the topic here so I might look for another thread.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=aed2d95a-4588-49dc-99ff-5b823f1a55b5)
    Like some of you, I'm back on my Mac which is my main machine anyway. This is my first Windows device.
    I know how difficult it is for software to interact with hardware. But the Surface is made by MS itself, so this should be better. It shows how complex Windows is. Apple completely abandoned OS9 and developed OSX and developed a modern, streamlined interface. MS has not been able to do this perhaps because so many users are reliant on different parts of the OS. Windows 10 has some nice simplified Settings pages, but mostly I have to hunt around in the real Control panels to do anything which makes it difficult for me to understand if you do not have a background in Windows previously. There are settings scattered all about and running a Search often does not find the one you want.
    2016-02-24T07:57:16+00:00
    alot of scaling problems but never seen that windows actually want to fix it for me :P
    2016-02-24T09:15:48+00:00
    New driverpack .msi up. seems to have helped.
    https://www.microsoft.com/en-us/download/details.aspx?id=49498
    *edit* No it did not. just as horrible. same with to other collegues.
    I've stopped selling the Surface to my customers now because of all the docking problems.
    2016-02-24T09:16:47+00:00
    Is it possible to download this update manually? I have a Surface Pro 4 and I can't see this update.
