2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-24T02:10:21+00:00
    it happened when I unplugged and SP4 went to sleep. I tried to wake it up but the screen wasn't on (but the keyboard was)
    2016-02-24T02:30:20+00:00
    This is under active discussion in the Surface Pro 4 - Screen won't wake from sleep thread. It seems the 2/17 update fixed things for some people, and messed them up for a whole lot of others.
    2016-02-24T02:41:02+00:00
    If you are from CNET, CNN, USA TODAY, etc and read our MS community forum, please post our complaints on your news. As firmware upgrade 2/17/2016 does not fix the existing problems. Instead, it creates more major issues. The SP4 battery only last 4-6 hours not even close as Panoy advertise above. We are lucky if we can get 6 hours. Panoy, do not BS ing us with your products and show your face here in this forum. I am very tired with $1K product and does not even work right.
    2016-02-24T03:39:48+00:00
    Unfortunately, I'm experience issues coming out of sleep as well.  This started after the most recent update.
