2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-23T23:32:24+00:00
    I updated my settings to hibernate instead of sleep and have had a reduced amount of errors.  Only 1 in the last 24 hours..... I know this may not work for some but it is better than the alternative.
    2016-02-23T23:56:59+00:00
    I have these updates installed and I have had this problem since early December. Really annoying.
    2016-02-24T01:10:28+00:00
    SP4 battery life sucks. I bought one not expecting the hyped 12 hours, but I was expecting to be able to go for more than a few hours without plugging in. And I was expecting that I might be able to forget to plug it in overnight with lid closed and still have some decent battery life left. My low expectations have not been met, and I am baffled by how much worse it is than the SP3.
    2016-02-24T01:55:41+00:00
    I've installed this (2/17/2016) update and still suffer from the same infliction. Surface Pro 4 goes to sleep and won't wake up. I continuously lose work having to "2-button" power cycle this device. I'm at the end of my rope. I had high hopes for Microsoft but fear I may need to return to my ever dependable MacBook. Please, anyone, help me repair my tattered relationship with my shiny new Surface Pro 4.
    S.
