2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-23T22:47:05+00:00
    Same here... before 2/17/16 Update I never had a wake issue with my i5 8gb SP4. Now waking from sleep is like playing roulette. Switching back to hibernate, when closing the typecover, makes it possible to wake the device reliable.
    I hope MS will address this problem as fast as possible.
    2016-02-23T22:53:35+00:00
    My surface pro 4 is up-to-date as of 2/22/2016. However, Whenever SP4 went to sleep, it can't wake. I always have to reset the machine. I thought Microsoft has fixed this!?  This is ridiculous! Is there a way to fix that?
    2016-02-23T22:54:27+00:00
    MS is very slow to respond compare to Apple. I am sure, MS is reading this forum. As an engineer, I can tell MS does not have good quality control. They release half cooked product all the time.
    2016-02-23T23:07:36+00:00
    Have been getting more successful wakes lately. No bluetooth devices attached so I know it truly sleeps. But now I have to watch if my battery life drops.
