2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-23T20:47:52+00:00
    If they really want to mock a device selection, contact me. We went with the top-of-the-line I7/1tb version which with peripherals and warranty topped out at about $3k. A lot to spend for a brick.
    2016-02-23T21:22:17+00:00
    Unless you're an Enterprise user, Ctrl-Alt-Del is only used to get to Task Manager to kill something that's gone off the rails.
    I don't think I've ever used Ctrl-Alt-Del at all in Win 8/10, since it's way easier to get to Task Manager and a few other "old-style" Windows controls by right-clicking the Windows button.  (And without the magic VolUp-Pwr trick adanowitz suggested above (new one to me), Ctrl-Alt-Del is impossible if you don't have a keyboard...)
    Keep in mind that the keyboard cover is OPTIONAL, and not everyone chooses to buy it.  (My son just bought an SP3 and skipped it.)  It's not safe to assume there is EVER a physical keyboard attached to a Surface device.  This is why proper waking MUST happen without any keyboard interaction at all.
    2016-02-23T22:22:20+00:00
    My problem now is that since the Firmware update of 2/17 my Surface Pro 4 will no longer hibernate (when waking back up it freezes on the Surface logo).  So I have two choices
    1. Use Sleep mode and hope that the device wakes back up without needing to crash out (works 50% of the time)
    or
    1. Use Hibernate which now results in 100% of the time crashing out and restarting.
    Great choices Microsoft - Thanks!!
    2016-02-23T22:42:21+00:00
    Wow, the only choice is to turn the SP4 off. At least mine works on hibernation mode so far.
