2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-23T19:33:38+00:00
    The update did nothing to help this problem on my Surface Pro 4.
    2016-02-23T19:42:31+00:00
    False Advertisement.
    2016-02-23T19:46:49+00:00
    Laura here is the power plan you are using:
    Anyways, I am using the following power plan (edited the default balanced plan):
    Sleep > Hibernate after > On battery: 30 Minutes
    Sleep > Hibernate after > Plugged in: 120 Minutes
    Power buttons and lid > Lid close action > On battery: Sleep
    Power buttons and lid > Lid close action > Plugged in: Sleep
    You are right , this setting only give my SP4 on sleep mode for a few second than it goes to hibernation.
    2016-02-23T20:14:21+00:00
    Do you guys encounter another problem?
    The problem is that when I connect the SP4 to the dock, all monitors are disabled. When I manually turn them on, it asks me to sign out to make the scaling correct. However, after I sign out and sign in again, all the monitors are disabled again. Then I turn them on -> sign out -> return them on -> sign out ... until they all are correctly enabled.
    very very annoying. I connect the dock to 2 monitors, and use an external monitor as my main monitor (instead of the SP4's screen).
    I think Microsoft does not really care our complaint. Who posts here already has a SP4 and is useless for Microsoft. Microsoft only puts its efforts on selling more devices. Existing customers? It is not Microsoft's business anymore.
