2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-23T15:50:03+00:00
    I have never used Sleepstudy but I will see what it reports as something is running and making the battery warm during supposed sleep.  Has anyone by chance tried this to see what is draining batteries, or perhaps conflicting with sleep?  It seems pretty clear that Sleep runs hot and thus is probably not a truly sleep.
    2016-02-23T16:03:08+00:00
    I agreed. There are not too many media website mentioning the failure of 2/17/2016 MS update. This firmware actually worse than before. I am back to hibernation mode again. The sleep mode is too risky when I place my SP4 in my bag. I am worry, it will cause fire and burn my house.
    2016-02-23T16:28:30+00:00
    Did you install the Samsung NVME driver to improve the SSD performance?  A sleepstudy will show you what is draining the battery in sleep but not necessarily describe it. I found by searching the internet that the Unregistered Device \_SB.PC10.RP05.PXSX defined in my sleepstudy listing that was draining the battery fast was in fact the Samsung NVME driver.
    What I learned is not to install 3rd party drivers on this device that aren't part of the MS update. If you have installed other 3rd party drivers I suggest you check them out first.
    2016-02-23T16:45:05+00:00
    same issue for me with last update :( screen stay black . only solution :Hard reboot
