2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-23T01:43:24+00:00
    Yes, fix it please...even worse after update...
    2016-02-23T01:46:56+00:00
    Josh,
    Thanks for your reply but I updated my surface pro 4 on 2-18-16 and just today my device display driver has failed to wake up, causing me to lose all progress on my work. This has been a constant battle ever since I got my surface a few months ago and this update has not appeared to chance anything.
    Danny
    2016-02-23T01:51:26+00:00
    even with the new system updates the problem persists with the surface not awakening from sleep or hibernation. still requires reboot to start up again.
    2016-02-23T02:55:00+00:00
    Another "ME TOO!" I had this issue a couple times a week before the update and now it's every other time I try to wake my SP4.
