2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-22T20:41:48+00:00
    I didn't have this issue until I updated my device, and now I am having this exact issue. Everything is up to date, but my SP4 will not wake from sleep. How can an update that fixes this issue make it start happening?
    2016-02-22T23:06:35+00:00
    My surface pro 4 is up to date and still having this issue as if February 22nd..  I'd say about 30-40 percent of the time it won't wake from sleep mode.  I have to hold the power button for 30 seconds for a hard reset.  I agree with other posters, this is an unacceptable issue for a product in this price range.  I've had 2 or 3 friends ask if I would recommend my surface pro 4, and unfortunately I've had to say no up until this point because of this problem.  I've been embarrassed more than a few times when trying to do a presentation, and I spend time trying to get my Surface to boot after trying to figure out why it isn't waking up.  Really leaves me regretting my decision to get the Surface or an Ipad at this point.  I hope this is remedied soon.
    2016-02-23T00:33:39+00:00
    I have exactly the same issue.  After the most recent update, it stopped waking up properly very frequently.  It was mostly working fine before that.
    I am not happy with the update making things worse.  Please fix this.
    2016-02-23T01:29:06+00:00
    I don't think the update did anything. After I updated it with the recent 2/17/16 update, my surface 4 went into sleep mode and I wouldn't turn on. I had to reboot it by holding the power button.
    Yes, my pro4 before 2/17 update no problem. After update start have the problem, keyboard wake but not screen.
