2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-22T06:44:33+00:00
    As posted previously, this update has solved the sleep issues on my i7/8/256.  Like others, I had just set everything to hibernate rather than sleep but I'm happy that sleep is finally working for me now.
    Sorry to hear the update has caused sleep issues for others...I love the surface as a product but it was frustrating when the thing wouldn't behave.
    Just a quick reply to Adanowitz on his theory.
    When I updated mine, it was unplugged, but I'm pretty sure I did have the keyboard attached although it may have been folded over the back.  I definitely had a micro-sd card in it.  It took two reboots to finish everything and its been perfect since.  Maybe a coincidence or maybe there's something to your theory.
    To those experiencing battery drains while sleeping...One thing I changed was the setting to allow it to stay connected to wifi during sleep.  I  turned the feature off and haven't experienced the battery drain since.  Maybe something else to try?
    Dave
    2016-02-22T07:28:35+00:00
    Hi All,
    Josh
    Initial result from the 2/17/2016 update was my SP4 i5 256 went from occasionally not waking from sleep, to always not waking from sleep.  I did a reset, which is a pain, but so far, fingers crossed, it is now waking from sleep. Battery still drains while supposedly sleeping.  Still gets inexplicably warm when plugged in.  But at least it's usable again.
    The improvement from doing the reset leads me to wonder if there was some setting or software I had that interfered with the update?  For example, I had set Battery Saver to always be on whenever on battery.  I have also not enabled "Hello" this time, which was enabled before the reset.  It was kind of gimmicky anyway.  There are sooooo many settings it's hard to know which ones if any might have been a factor.  I'm going to take it slow in customizing any settings from factory defaults, and in adding back other software.
    This is a wonderful product but really unstable.  MS has pushed innovation the last couple of years at the expense of stability.  Not a good trade off, in my view.  "It just works" has to be the response of the users, or there will be pitchforks and torches.  Something like waking from sleep is so incredibly basic, and has been a feature on a wide variety of machines for years, so it is pretty much expected.  I'm not at all technical; don't know what it takes to make this stuff work.  But frankly, I don't think I should have to.  It should just work.  That is the expectation, and I think it is reasonable.
    2016-02-22T07:48:24+00:00
    I just got my SP4 a week ago, and occasionally it would have trouble waking from sleep. Now, after the update, it seems that I have to hard reset every time my SP4 sleeps for longer than about half an hour. This is completely unusable for any situation and I am hugely disappointed.
    For a machine in this price point the SP4 shouldn't have issues just sleeping and waking, something even budget tablets/computers do without problems. Please fix, Microsoft. So far this purchase has been a disaster.
    2016-02-22T08:19:17+00:00
    Yesterday, I rolled back the graphic driver too. At first I thought that the issue was fixed but today I could not wake the SP4 after a connected standby session (display driver 4326 installed).
    Before rolling back the display driver I read on reddit, that Windows Hello might be the perpetrator. But for me, disabling Windows Hello did not fix the problem.
    I hope Microsoft will address the problem as fast as possible.
