2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-22T04:10:22+00:00
    Fingers crossed. I have not had issues with either of my surfaces (sp4 i7, s book) since the update). But battery life is diminished.
    The machine still suits my needs, but frustrating.
    2016-02-22T04:51:52+00:00
    What I really find hard to understand is why I am now seeing this issue after the 17/Feb firmware update.  I very occasionally had a return from sleep failure before that, but now it has occurred every day.  If Microsoft did any reasonable amount of testing of this fairly fundamental problem I can't see why they didn't see the issue as I do.  And I am not even looking for it ...
    I really do love the Surface Pro 4 but this is such an annoyance and it is tarnishing the whole experience.
    I can believe that it might be a tricky software bug to fix, but we have waited months, only to be severely disappointed.
    2016-02-22T05:05:09+00:00
    This is a very interesting thread. I had to deal with the frustration from this "unable to wake from sleep" issue since November but the 2/17/2016 update seems to have fixed it for me!
    For those that encountered this issue for the first time, I feel your pain. I have lived through it for 3 months (hibernate to the rescue) and now it finally seems to be fixed for me.
    UPDATE:
    I have continued to test it and determined that the "unable to wake from sleep" issue is not fully resolved. In my case, it seems to be going to sleep and waking up fine as long as power supply is not involved. But with power supply (I use Surface dock power cable), I have been able to find a couple of scenarios where it still fails to wake from sleep.
    Scenario 1: If Surface Pro 4 is disconnected from power supply and I close the lid, it goes to sleep per my "close the lid" setting. While it is sleeping, I connect the magnetic power supply cable. Now when I open the lid and try to wake it up, the IR light and keyboard light up but Surface fails to wake up from sleep. I have to close the lid again to make it go to sleep mode in power supply "connected" mode. Then it wakes up on opening the lid and pressing a key/button.
    Scenario 2: If Surface Pro 4 is connected to power supply cable and you close the lid (it goes to sleep) and then you disconnect the power supply cable and then open the lid and press a key, it won't wake up from sleep. The IR light and keyboard light up but screen stays dark. I have to close the lid again to make it go to sleep mode in power supply "disconnected" mode. Then it wakes up on opening the lid and pressing a key/button.
    So the bottom line is to try to wake it up in the same power supply cable connected or disconnected state that it went to sleep in. Otherwise, close and open the lid a second (or sometimes 3rd) time.
    I will post more as I test more.
    2016-02-22T05:16:15+00:00
    Hi All,
    Josh
    Thanks, but no-go. I have the updates from 2/17/16 and my Pro 4 (i5, 128GB) still will only turn on half of the time. In fact, to get online to write this question I had to do a hard reset to get it to wake. Any suggestions?
