2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-21T14:07:56+00:00
    I am going to do another Reset of Windows 10 and this time not apply the patch. I got my SP4 2/17 so I don't have much data / apps to lose. If the issue continues I'll just install the update back, continue using Hibernate and wait for a fix.
    2016-02-21T15:13:59+00:00
    Per my original findings, I only have Sleep issue with SP4 when cover keyboard is attached. See my thread here:
    https://www.reddit.com/r/Surface/comments/46lr02/sp4\_doesnt\_wake\_from\_cover\_sleep/
    With cover keyboard on, I have to workaround with Hibernate. With just tablet Sleep does work (even with Bluetooth mouse connected.
    2016-02-21T15:30:23+00:00
    I stand to be corrected but is this not a firmware problem rather than a Windows 10 problem?
    2016-02-21T15:33:49+00:00
    From people's research it seems to be a graphics problem both with HD 520 and Iris 540. But I can't see how that relates to Hello Windows and the cover. Without the cover I sleep fine.
