2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-20T23:36:16+00:00
    Update:
    After experiencing 2 wake hard reboots, decided to roll back the graphic driver.  Not sure if related to my system restore or the replacement of this one driver which was forced updated onto my system, but system appears more stable.  Will need more time to see if I was successful in rolling back the 2/17/2016 update.
    I rolled back the 1/12/2016 driver (4364) which was associated with the “System hardware update 2/17/2016” to my original 11/20/2015 (4326) driver.  I believe this will correct my problems and return my SP4 to a stable condition.
    You can roll back this driver by going to Device Manager -> Display adapters -> then Update Driver ->  “Browse my computer for driver software” -> “Let me pick from a list of device drivers on my computer” -> See picture below – select the 4326 driver.
    Your screen will flash and the font will be temporarily reset to a larger size.  Reboot the computer and you’ll be back in business.
    If you don’t have the 4326 driver, you can download it from Microsoft’s website https://www.microsoft.com/en-us/download/details.aspx?id=49498.  You’ll need to copy from the zip folder (that you just downloaded) named “Graphics” and save it somewhere on your harddrive and reference that location when you hit “Have Disc…”.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=059459bc-b998-429e-b1d7-658f61289a73)
    2016-02-21T00:19:01+00:00
    How do you think I feel, I just got the device 3 days ago :)
    Hibernate does work, with Windows Hello. I guess I'll stick to that until a solid report comes that fixes Sleep state.
    2016-02-21T01:26:00+00:00
    The issue is NOT fixed with the most recent update.
    my device used to be fine but it has updated yesterday (2/20/2016) and today it fails to wake up from sleep
    2016-02-21T02:11:14+00:00
    I got this problem after install Surface update (HW and Firmaware) from official website. Before it worked great.
