2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-20T20:22:39+00:00
    The update didn't fix the wake up problem, but just make it worse.
    2016-02-20T22:13:14+00:00
    Do NOT install the update, made things worse.
    It was working with Win key + P, now it does not.  Goodneess MSFT, what a shame.  at least dont make the problem worst.
    how to uninstall this update?
    2016-02-20T22:53:54+00:00
    I am seeing about the same rate of wake not working. Now keeping 4380, but disabled Windows Hello.
    2016-02-20T23:23:36+00:00
    yes but some of us didn't have this problem before, everything was fine including Hello, but now we do!
