2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-20T19:45:18+00:00
    Hi All,
    Josh
    Unfortunately the update does not address the issue.
    On my SP4 (i5), I have a black screen after waking up, most of the time. It actually seems worse after the 2/17 update.
    The WIN+P workaround no longer works. The only way is to hold the power button for 10s for a hard reset.
    And I tried to completely reset W10, no luck...
    I hope we have a fix soon. Because announcing a fix that does not work is actually worse than acknowledging the problem.
    Panos, I have faith in you. Fix this!
    2016-02-20T19:58:26+00:00
    I installed the beta driver for Iris 540 to see if that has any effect.
    with 2/17 update:
    January 12, 2016
    20.19.15.4364
    beta:
    February 2, 2016
    20.19.15.4380
    2016-02-20T20:04:36+00:00
    The beta driver (4380) was actually worse on my SP4 i5. Black screen after EVERY sleep.
    2016-02-20T20:12:27+00:00
    I have only had this problem since the update.  Is there any way to undo it?
